heating problems with 3500+
sarconus
I am having some strange heating problems with my cpu.
I have the msi neo4 platnium sli MB with OEM 3500+.
I currently am running at 2750 and im running at 46c on idle and 56 on full load. I ran prime 95 for 8 hours and had not problems. This is stock voltage as well.
I unclocked my system and im still running the same temp. Im using cpufan utility and it displayed the same temp.
I am using the xp-90 with 92mm fan on top with artic silver. I have reseated the heatsink 2 times and i get the same result every time.
Any suggestions or is this normal?
Normal, motherboard sensors aren't perfect. Also, how is your airflow?
As long as everything is stable, and you get consistant results and a decent OC, what more do you want :)
