Ok, I just got my heatercore from autozone, which sucked. The people there will do anything there to make you seel bad, ohh well.
Ok, about the core. Is it normal to see corrosion on it new? Just curious, now the real question: How can I get the hose barbs on it? The tubes are ovalszed on the core, otherwise I was going to solder them out and thread the barbs in place.
I'll get pics up of it tonight...later
edit: It just occured to me that since it will be painted anyways, I could just modify the end of the pipes to make the barbs fit on somehow, I really don't see any other way to do this right now...
on a side note, where can I find brass barb fittings more easily? I went to menards(only plastic ones), stein mart(brass but not the right size), and fleet farm. But even fleet farm still didn't have a brass female one...later
