I'm seriously considering water cooling, but there's something I don't know the answer to. I was going to go with a heater core (either single 120mm fan or dual, whichever I can fit in my case), but I don't know if any of them are copper or not.
The Black Ice radiators are listed as having a copper core, but DangerDen for one doesn't say what the heater cores are made out of. I don't want different types of metals in the loop as to avoid excessive corrosion.
Anyone know if DangerDen's heatercores are coppere, or if anyone sells copper heater cores? I just want a cheaper radiator, and the heater cores are 1/2 to 1/3 the price of the Black Ice Xtreme or similar.
Also, ideas on how to fit a dual 120mm radiator into a Chieftec/Chenming/Etc Dragon case are welcome. AFAIK, it would have to go in the top. But due to PSU placement, it would have to be partially on top of the optical drives, and as I can figure would only leave about 1" of clearence once the fans are attached. Is this enough? My other option here would be to mount it primarily on top of the case with a shoud enclosing the fan & radiator and going all the way down to the top of the case (which would end up looking sorta like an EXOS type system).
For the front, I've already moved my HD mounting enclosure up to the floppy drive bay, but there's only 8 inches of clearance below it. Most duals seem to be 10-11" tall. I suppose I could relocate my HDs to another part of the case, maybe a custom mount above the optical drives.
In the rear it's totally impossible to fit 2 120mm fans.
TIA
TIA
