kill4killin
- Jul 3, 2006
So for my next build I'm going to be doing a complete wire overhaul unless i end up getting the M12 (in which case i may end up doing it anyway depending on cable length).
My question is for shrink wrap, do you need to have a special heat gun or is a hair dryer hot enough to shrink to tubest to fit the wires?
(And a side question for those who have done this, what gauge wire should I use?)
