Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
A heatpipe is just a pipe where heat can pass from one area to another. Several heatsinks (like used in shuttle computers and thermalright sp94 heatsinks) use heatpipes.
Do some google searches for heatpipe and you should get some interesting results.
I need a heatpipe for an SFF box. I would like one with a radiator-like thing attatched to the proc via heatpipes, not the kind where the heatpipe connects the bottom of the heatsink to the top.
a heatpipe is not just a pipe, it's a pipe filled with a vaporizable liquid. Heat is absorbed in the evaporating section, fluid boils to vapor phase, heat is released from the condeser section of cylinder to the environment; vapor condenses to liquid phase, liquid returns to the evaporating section.
