Greetings - I have a 1950X, ASROCK Taichi mobo and a Kraken x62 cooler
When I run the software with my x62 it shows temps some 30 degrees C cooler than the ASROCK hardware monitor. Obviously this is conerning since my asrock tool is shoing 89/90 c under stress load ( just a few minutes of 95 prime) and the Kraken is showing 59/60 c which I would be much happier with. Any thoughts as to why the two are sooo different? Kracken is installed correctly as far as i can tell I know it does not cover all the heat spreader but that seems very hot.
