EndersShadow
- Dec 27, 2008
I see that most/all aftermarket coolers are now coming with their own custom backplate to use when mounting. This can sometimes cause compatibility issues.
I currently have the ASRock A75M-ITX motherboard which put some of the SMB components in the AMD keep-out area around the FM1 socket. Currently I have a Silverstone NT07-AM2 installed on this board (with the backplate) and dont have any issues. I however do not like the noise profile of this cooler and am wanting to replace it with the Noctua NH-L9A. On the Noctua website it says this board isnt compatible due to the SMB components on the back of the motherboard.
My question however is do you really need the backplate for as small a board as I have or can I get by without it. I have seen a couple instances of folks doing without the backplate on different coolers on a similar board (http://techreport.com/forums/viewtopic.php?f=33&t=83983&start=30#p1141367) so I am just curious. I thought about cutting the backplate to accomodate those pieces but that wont work either. I could probably use rubber washers (since plastic melts and that area tends to get hot) between the backplate and it would work (and I have had this verified with Noctua itself), but am just curious.
Thoughts appreciated.
