The PC 150 stereo headset has the ultimate real-life sound
that will make it seem like the action is right where youre
sitting. A fantastic piece of technology that offers a highvolume
experience no one should have to live without.
􀀗 Adjustable headband for perfect fitting
􀀗 Adjustable, bendable and pivotable microphone makes
the voice more clear and increases comfort and flexibility
􀀗 The noise-canceling microphone provides for high speechclarity
and voice recognition by filtering out the noise
around you
􀀗 With the in-line volume control and the microphone mute
switch you can keep sound at the right level or have a side
conversation in privacy
􀀗 Equipped with a single-sided cable for maximum freedom
of movement
