Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have a pair of MDR-V6s that I would like to use with some sort of headset type microphone. All the ones I see have some sort of headphone/earphone built into it. Are there any 'plain' ones?
I don't think I've seen any, but I use my Allesandro MS1's for headphones and put a headphone/microphone set around my neck, angling the mic up towards my mouth...works fine.
I've done every option, and I have V6's as well. Here's what I've tried...
1) Taking cheap headset, breaking head part off and taping the mic boom onto the V6 headphones
2) Taking a small clip on mic, and taping it to the side of the headphones (picks up voice surprisingly well)
3) Wrap a mic around your neck, and let it dangle
4) Just sit the mic on your desk somewhere. You wouldn't think so, but this is just as clear and works great. It's my new method since I have one less wire to deal with. Just sitting on a shelf near my monitor.
