Headset / SoundCard
therealdrag0
My current headset is Sennheiser PC150, but I'm not a big fan of the ear pieces. What would be a good headset that has leather like ear peices? [~$50-80]
My current sound card is a gramcracker... and being a comptetitive fps player I want to be able to hear people around the map what would u recomend? [~$100+]
Thank you!
drag0
Since you plan on using headphones, ignore that and get the X-Fi. The updated CMSS-3D Headphone mode puts the ZS to shame. Plus you can run heavier load cans on it. The opamps on the ZS are only really rated up to 32ohm units.
As far as cans go, you want circumaural, so they rest aound the ear, and not on it, for best comfort over long periods of time. That pretty much rules out Grados. If you want closed cans so others won't hear you, I suggest the Sennheiser HD280s. Otherwise, the HD5xx series, or Beyerdynamics. I sure a few others will be mentioned shortly.
Best suggestion is go hit an audio store, and audition several, and hear what you like most. Try and keep the Ohm rating down to 50-120 with the X-Fi.
If you also plan to have external surround speakers, I suggest getting a model with a breakout box, so you have a dedicated headphone port.
