Headpunter
- Mar 16, 2008
ok so i know it isnt exactly twice the case but i think it will be when im done
I bought a cosmos 1k after looking at different cases at newegg, i thought the cooling would be substantially better but i was dupped, so in preperation for putitng several radiators and water blocks all over my motherboard and processor i decided to put some case fans in the side till i could afford all the parts for my Water cooling set up.
i decided to set the spacing on the fan's screw holes so that i could use Swiftech QP radiators, i can only fit a 1x2 in width wise so i went with a 2 sets of 2 fans that will turn into two 1x2 radiators
i marked it all out on a piec of optix polycarbonate i bought at home depot
i then did all of my layout using an outline of the side panel for reference of were everything was going
i then took a drill and drilled all of the screw holes and
before i layed it out i covered the sheet in masking tape though
after i covered it so i could use pencil to lay out i did a full layout of the radiators screw holes for attaching the fans
after i marked everything up i decided to drill the centers of were the fans were going to go and the screw holes
after this i clamped the sheet to the side panel of the case i then used a drill to punch the small holes thru the ones in the plastic all the way through the aluminum side panel
pictures didnt really turn out the well so we can skip em
after that i used the smaller holes to match were the bigger ones were to go, i then used a hole cutter in my drill press to cut out the fan holes (except for one annoying hole that i had to use the hole cutter in a battery powered drill to reach)
after this i drilled the screw holes out larger to fit the large screws to hold them, since i couldnt reach all the screw holes with the drill press i used a battery screwdriver to drill the middle 6 screwholes with the fans screwed on with the holes i had been able to reach screwed already, just to make sure the position was correct
i got all the fans to check alignment but still needed to smooth the edges on the holes so i took them back off and sanded them down using 220grit sandpaper, with the holes cleaned up i put the fans back on and mounted the "filters" i put them on the back so i could keep a semi industrial feel to the side of the case.
i then bundled the wires on the fans so they would be tight to the side panel so they wouldnt get crimped while closing the case
i then cut the sound deadening to fit around the fans and re installed it
i then reinstalled the side panel and plugged it in and here are the final pix of PHASE 1
if you have any suggestions for the water cooling part of this feel free to comment
thanks hope you enjoy the pix will have more soon
edit: thankyou Arcygenical for the info on buying fans other help with picking out parts
