Badger_sly
- Mar 20, 2002
I just have a few questions for the headphone gurus here, which I'm not.
I've never needed headphones before, but due to my wife change in work schedule, they sure are needed now. Anyway, I have the headphones already, and I have an Audigy 2 ZS (no pro or platinum, just the card).
From what I've read so far, I plug the headphones into the Line 1 Out Jack. Is that correct? Also, will I only hear from my headphones the sound that would normally go to just the front speakers? Or, does changing the speaker type, under advanced of sound and audio in the control panel, or changing the speaker type in the Audigy2ZS speaker setup application, to headphone from 4.1, somehow send the front and rear sounds to the headphones?
And one more question, I currently have 2 recievers/amps that take the signal from the Audigy and output it to bookshelf stereo speakers (front to 1 amp, rear to the 2nd amp). The amp that outputs to the front speakers has a headphone input jack, not the 1/8" mini / it's the larger plug input. If I were to get an adapter and plug headphones into this headphone jack on the amp, will I get the same output as plugging directly into the Audigy Line 1 Out Jack?
I hope someone can understand all of that^^
