Any idea how? Based on looking at the backs of some subwoofers I'd wager that I need a receiver or something.
][V][AGIC;1035053602 said:Is it a powered sub?
The audioengine AS8 should plug straight into your soundcard.
Use a splitter, before the signal goes into the headphone amp.
if the sub has an LPF on its input
and you aren't doing volume control with the soundcard/source device
and you don't mind adjusting the sub's volume on the sub, not anywhere else
as far as connecting it, if you have RCA in/out (some subs do), do that, and just run the amp "after" the sub in the chain, set the xover low
alternately you could use an output from your headphone amp into the sub
the issue with splitters is you only get one channel in or you get crosstalk
- Most cheap subs do.
- This is just wrong.
- This is also wrong.
- The type of input is irrelevant, but RCA is most common since that's pretty standard for consumer-grade line-level audio. Connecting the headphone amp after the sub is electrically identical to using a $0.50 splitter, so if you have a passthrough output on the sub feel free to do this if it makes the wiring easier. Well, I lie - it makes your run to your headphone amp longer, meaning that you can have phase or capacitance issues if the run is long enough - but for headphones you should be using short runs anyway.
- Presumably the output of the headphone amp is amplified, and chaining amplifiers is a total noob move that can do lots of Bad Things from screwing with your sound quality to outright frying your equipment. Exception is of course a preamp/power amp scenario where they are intended to work in stages - which should only be done with appropriately designed amps that are expecting to be used in this manner.
- This is also just wrong. You have a cable for left and a cable for right, and you put a splitter on each. How you even got this idea is beyond me.
