On the other hand, most High Z cans are much lower in sensitivity than most Low Z cans are. That is due to the fact that High Z cans require a much larger voltage swing than Low Z cans of equal dB SPL @ 1mW efficiency. Ever try a High Z can on a portable player, only to find out that the sound is too low in volume compared to a Low Z can of equal or lower "sensitivity"?Mister X said:That is a common misconception.....
Low Z cans usually need a amp worser then High Z cans because they require more current to drive them.
Although dated this rane page demonstrates my point very well------>>http://www.rane.com/note100.html
iownyou14 said:I guess I need an amp. How are the amps powered (battery or plug-in)?? Im not really a DIYer so im looking for a good priced pre-built one.
Im looking @ this one: http://www.headsave.com/homevibe.html
