headphone+mic splitter?
DF-1
Hey guys,
I was looking for new headphones and after a lot of research I decided im going to order the ATH-AD700 which people are saying are very good, and they are in my price range.
now the AD700's don't have a mic with them, so I thought I would buy a mic like this zalman clip on:
http://www.amazon.com/Zalman-Microp...1?s=electronics&ie=UTF8&qid=1315071341&sr=1-1
Im going to mainly be using this for my PC (mostly gaming).
but I also would like it use it very occasionally for my cell phone. and that has only 1 plug (2.5mm i think)
I've been googling away for a splitter/adapter that can give me both audio and voice into one plug so i can use it for my cell phone, so far the only thing I've gotten was two 3.5mm audio's like this, which im not sure would work
http://www.amazon.com/Belkin-F8V234-WHT-APL-Headphone-Splitter/dp/B0000UV2AW
is there any way that I could get functionality from my headphones + a clip on mic for a cell phone?:confused:
I think you might be able to make one. I believe the jack on the iphone for example is a 3.5mm jack with LR+extra+ground (4 conductors, not 3 as a standard 3.5mm stereo jack is). I think if you bought a 2.5mm socket that had 4 conductors, and some wire, with 2x3.5mm jack sockets, you could DIY your own adaptor. Although, having said that, I haven't personally tried it, and of course your phone might be different!
