headache with my mobo's memory config....
Dcamel
ok, it says in my manual I can have either 1 SS/DS chip in any slot on my board of DDR400 RAM, an SS/DS in slot 1 and then an SS/DS in slot 2 or 3, or 3 SS. I only currently have one slot filled with a 512 stick, but I dont know the difference between an SS or a DS (I just know it means Double or Single sided). the real catch is, if Im doing two I have to use two OPPPOSITE kinds of ram, so if I use an SS on slot one the one on slot 2/3 has to be DS...but I don't know what I have or what I would be ordering, and I don't know how to tell em apart...plz help me! :(
Literally look at the RAM, does it have the black chips on both sides? It is then double-sided. Easier then you thought, eh? My motherboard manual says I can't do DDR400 with more then one doublesided DIMM, but I'm running at DDR400 with all three slots filled with OCZ doubesided 512's. AMD officially doesn't support it, but manufacturers like to get creative and figure out ways of doing things. I just had to take the RAM speed off of auto in the BIOS (it would default to 333) and specifically set it to DDR400. Don't be afraid to give it a shot. Of course I have the MSI K8N Neo Platinum, the Epox may not allow that I don't know... As for buying new RAM, if you research that specific RAM on the manufacturers website then you can usually find out ahead of time if its doublesided or singesided.
heh, well I checked both Geil's (the RAM I own) and Corsair's (the RAM I plan to buy, the value) and I can't find the info. Is DS usually more expensive? Does the DS/SS designation make a performance difference?
ok, the RAM In there now is DEFINITLY DS, based on the description you give. But none of the pictures or info I find on the web tell me if the RAM I am trying to buy is SS or DS...
