MaMMa said:nice article, I'm gonna try it. Any one of you guys made one yet and how did it go?
Starter Kit
<snip>
Rough grand total: $80-120
Mister X said:Some of us have a different notion of what sexy is.![]()
would that seriously work?BillR said:If you have a receiver and some talent your set. Get a mini box from Radio Snatch and a ¼ headphone jack. Solder a pair of 100 watt 100 ohm resistors (wire wound resistors are best for this) across each channels positive and negative. Run speaker wire from the jack to your speaker out on your receiver. Bingo, affordable headphone amp.
What do the left/right channel LED setups do X?
ive got my headphones hooked up to my dads old 480W Pioneer stereo amp, through one of 3.5mm Female to 1/4" Male Adaptors (it does the job)
would it sound better going through the the speaker outs?
Mister X said:Input level display.
Its just some amp bling bling is all.
So does it just the input level just measure how much/the amplitue of the left or right channel and output it in a bar graph (via leds) format?
Nope, it's pretty much a standard LM3915 implemenataion.Did you design the circuit yourself?
