Dont know much about them im wondering if the is a good bang for the buck thing or not
School me
http://www.zzounds.com/item--BEHHA400
School me
Or you can just buy my Cmoy amp for $50.It's pretty good bang for the buck.
No idea but for the $$ it will do better than a X-Fi headphone out. Depends on what cable you use to connect it though. A cheap ass radioshack cable will sound pretty muffled in my experience. Spend at least as much on the cable and it should sound decent with most headphones.
my combo : DT770/80 PRO + pa2v2 ( 56$ directly from gary's website ) + 27$ for the 4copper http://www.head-fi.org/forums/f21/twisted-cables-bolder-cables-mini-mini-cable-shootout-328251/
The PAV2's volume pot has too much distortion.
Get a Fiio 5, the next big thing for cheap, good amps!
Really though, a mini3 or headroom total airhead should be the minimum for an amp.
