Hi all,
I've been thinking about getting a head mounted display for a while as I would like to get my Wife a new computer [most likely a Mac] for her birthday and need to move my system somewhere else. Rather than setting up a second computer in our already cramped office I was thinking that I could just sit my computer somewhere near my audio rig [headphone based] and wear some sort of glasses based display. I've been doing some looking around to try to see what is out there in terms of units that can be connected to the computer easily. The system I am using is listed in my signature, but the monitor would likely be used with my Wife's new computer. The head mounted display would need to use either a SVGA or HDMI connection so that I could hook it up to my video card. I was hoping to find something with a decent resolution, but it does not necissarily need to be the 1680x1050 that I am used to with my current LCD.
I found this one, but it is a quite a bit more than I would like to spend: http://www.vrealities.com/i-visorfx601.html
I found quite a few that are cheap, but they only have the standard hookups for use with a television.
Is this worth persuing or is the technology just not mature enough yet to be considered for computer gaming/web browsing [my primary uses]?
Here is a picture of where I would be using it for reference. The display would have to be reasonably slim so that I could wear it with my headphones and I would prefer a unit without built in sound for the same reason.
Thanks in advance,
Jason
Thanks in advance,
Jason
