Hdtv
Madhouse
HI... i built a HTPC with a ati 9600 AIW
i bought the vga -> component adapter as well
my tv is a Sony KP 46WT500
it has the component inputs on back.. the tv says its "hdtv capable" not "hdtv ready"
does this mean i have to buy some extra equipment and run my video card output into
that component then into my tv??? thanks in advance
you should be more or less all set. Just run a component video cable from the adaptor to the TV. You may also need powerstrip to tweak things out and make it look right on your TV.
Also, make sure the switches are set on that ATI adaptor to match your TV. The service manula for the TV will tell what you need.
edit: HDTV capable means there is no HDTV off-air tuner, and it just has the HDTV compatible component input, which is what you need.
ok cause i hooked it up, set the adapter to 1080i / 16:9 and when pc boots its all wavy and moving sideways and stuph.... will power strip fix that?? thanks in advance
I recommend 720p myself. seems to work the bes on most Tv's and still looks very nice.
It locks up damn near perfect on my sony. don't really even need PS.
Madhouse said:
ok will try 720 when i get home.. thanks for the help fellas
you may also want to try hooking up a regular monitor to the other port, and adjust settings for the TV to roughly what you want. then unhook the VGA monitor.
Ok so i come home and change dongle settings to 720p and i also realized that it must be on the vga 2 out or it wont work.... so i boot into windows and go to display properties .. then i go to advanced.. then theres the option to use component there
YPbPr is now available to click.. so i click it and it says resolution on it is 720x480@30Hz.. i reboot my pc and the tv starts giving a picture when it gets to the windows login screen... then i notice the icons are like off the screen to the left, my start menu off the screen to the bottom .. its like i have to scroll to get to them.... any way to fix this>??? thanks in advance..
with a true HD res, there is going to be overscan, which is what you are seeing. most front ends account fo rthis in some way, and it barely effects movies, if at all. You can use powerstrip to create a custom res, but then you don't have the exact HD res. your call. Myself, I don't use the desktop much, so overscan doesn't bother me.
well after messing around wit a bunch of the resolutions that powerstrip has to offer
i see that 864 x 648 fits the screen perfect end to end top to bottom... i guess i should be happy with this.. i really didnt like scrolling to the left to find my icons or scrolling down to get my start menu
so you actually use the desktop? I am always curious about this, what do you access formt he desktop or start menu? what front end do you use?
I actually havent chosen a front end yet.. ive been playing with meedio but not sure if it'll be my final choice..
ahh. i use meedion and have menus set up to launch all the apps from within the front end. I only see my desktop if there is a problem witht he PC.
