Hi,
I've been looking into having a dual monitor setup one of the scenarios would be to use HDTV via TV card on one screen while gaming on the other screen. My question is since the TV uses the graphics card to display the image does this give you much of a performance hit if playing the latest in FPS games such as FEAR, HL2 etc?
If it is a significant performance hit in that scenario do they make a HDTV card with its own output to the monitor so as to avoid using the graphic card's performance at all?
I like the idea of dual screens and gaming on one and TV on the other but since GPU performance is at a premium cost if its using the GPU used for gaming then id rather look into other options like a HD set top box connected direct to the monitor.
Thanks in advance for any assistance.
