HDTV and MythTV
Robizzle01
Quote from another thread, I didn't want to hijack that thread with personal questions.
bobbydole said:
Lets see.. I've use the Fusion cards.. however many people using Mythtv like the pcHDTV cards, http://www.pchdtv.com/ , because they're made for linux. There are also the avermedia cards, which should work fine too (as long as you have 2.6.15+)
You can get the avermedia and Fusion cards here:
http://www.pcalchemy.com/index.php/cName/hdtv-tuner-cards
Remember that the best you'll get for HDTV is what ever is OTA. You can use MythTv to decode the QAM channels, but usually those channels are just whatever OTA channels you'd get... When I set mine up this way, I got the OTA channels plus some other loser channels that I never watched.
What are OTA and QAM? I'm guessing over the air and ...not over the air? I just got a HD TV and i've been using mythtv with my hauppage 150 for almost a year. Now i'm dissapointed in the picture but I didn't know of any hd tuners for linux until I saw this post. I have a couple misc questions about these cards.
It seems like in every other thread the instant response for anyone wanting a tv tuner in linux is the 150. If these hd cards work so well and seemingly cost only a little more, why not recommend the hd? Surely, it should last longer since thats where tv is going eventually.
These cards can record non-hd channels as well i'd assume, yes?
For anyone that is using one of these cards, what kind of file sizes do you end up with for hd recordings? (per 30 min, per hour, whatever just specify please.)
As for using my 150 on my hd-tv, are there any tips to getting a better picture? I found out about the interlacing setting in mythtv and that helped a lot. Also, cranking the bitrate up makes a noticable difference but at some point the hard drive just fills up too fast -- what bitrate and other settings do you all use?
I have a AMD 64 3200+ and radeon 9500 with 3d working. If I launch mythfrontend from terminal and playback either livetv or a recording, I get messages in the terminal saying that my system can not play the video back at full speed and that some frames have been skipped to ensure audio/video syncronization. That was when I was running 1920x1080, I cranked it down to 1280x1024 (which unfortinatly makes everything in linux look stretched too wide) I still get these messages in the terminal.
I can't notice anything wrong with the playback but I wanted to ask if this is a common problem, if I can fix this easily, and/or if my system is simply too weak? I just played back some quicktime 1080 trailers in 1920x1080 and they looked great. I only ran into problems when I tried to move the window during playback -- then the a/v was off. Anyways, I would think if I can handle that, then I should be able to do mythtv just fine.
Any thing else you think I may want to know is welcome as well. Thanks in advance for help and yes, I did run some forum searches and google searches before posting.
Mythtv is, regrettably, not a particularly good video player. The backend is pure gold, the frontend is "meh".
Try turning on denoise3d to improve PQ.
People usually don't recommend the HD cards for SD because they're more of a challenge to get working.
OTA = Over the Air, QAM is basically the digital channels your cable company send you.
Most of the stations are encypted and can't be viewed unless you have a cable card supplied by the cable company. However some of the cable companies will suppy the OTA HD channels (plus some others) un-encrypted, so you'll be able to record them. When I set it up, I was able to view all the OTA stations, local access stations, and some other random cable stuff, and random on-demand stuff..
This is a trick question. Yes they can. The digital encoder chip on the card will record both HD and SD digital channels. However for normal, analog cable the encoder chip will record it also. However on the card I've got it's done in software, not hardware, and I can't use both recorders at the same time. Must people use them to record OTA stuff so using the second tuner doesn't help. Many people don't have an HD tv, or hardware that is fast enough to view HD, so the PVR150 will work for most people.
I have a couple CSI's in HD they run about 7-8gigs. I recorded some SD digital stuff, and it was about 800megs per 1/2 hour, which is less then SD recorded using my 150 which uses about 1gig for 1/2hour. Digital stuff always looks much better too.
I can't really help you with the other questions, my 150 is pretty much looks like my Tivo, and every other DVR solution i've seen. you might want to look into the mythtv mailing list, it is really active..
It does seem like that cable companies are more stations to their Digital lineup, there's some people from chicago complaining that there is no more basic cable anymore, since all the stations on digital you need a QAM decoder, or a cable box. I've also seen some TV displaying that they're able to decode QAM too.. they're basically running out of room in the tubes I guess.
