Basic System Info:
Case: Antech NSK 6500
CPU: Core 2duo
MB: ASUS P5N-E SLI
Video Card: ATI Radeon X1300XT (I know
HD's:
60GB IDE - Cable select
80GB IDE - Cable select
120GB External FireWire - Music
160GB SATA - OS installed on a partition here
New:
250GB SATA
250GB SATA
Senerio:
Everything is/was working fine. 120GB External is maxed out with music. So I figured I would order 2 new internal 250 SATA HD's and put them in a RAID configuration for back up. Simple plan right?
Today I installed the 2 new HD's & partitioned them. Took about an hour. I did this with the side panel off. After that I transfered the music from the 120GB to one of the 250GB's. Took another hour or so. Didn't get back to working on the computer until hours later. This whole time the side panel was off and the computer on. Now the 60GB & 80GB IDE HD's are not showing up.
Huh?
All hard drives showed in the disk management utility earlier while configuring the new HD's. I power down the system and back up. Still missing drives. Short cut on desk top said path was no longer working make sure HD is configured correctly. HD's were HOT to the touch. Powered down and let sit for 10 min. Powered up still missing the IDE's.
Now I powered down and unplugged the new 250 SATA cables powered up and bingo the IDE's are back. Huh?
1) So what is the problem?
All drives showed up at once before in the disk management. So I figure it can be configured this way.
2) Is there a limited number of HD's the MB can support?
3) Am I taxing my P/S? 430Watt (came with case)
4) Did the hard drives get to hot due to having the case open? If so why just the IDE drives?
I'm lost any ideas or suggestions?
Thanks in advance!
CPU: Core 2duo
MB: ASUS P5N-E SLI
HD's:
New:
250GB SATA
250GB SATA
Senerio:
Huh?
Thanks in advance!
