hdr wont enable
jetfire
got 3 ben q 32" 4k monitors but can only enable hdr on 2 monitors in windows if i try enable the 3rd monitor it just turns back off ?
using hdmi and 2 display port connectors
display 1 3840 x 2160 59hz 10bit rgb hdr display port
display 2 3840 x 2160 59hz 8bit ycbcr422 sdr display port
display 3 3840 x 2160 60hz 8bit rgb hdr hdmi
evga 1060 6gb gfx card
Are you sure those monitors support HDMI 2.0a / HDR over the HDMI port?
How are new DP cables going to fix the HDMI not working?
I had a job helping a one armed person make capital letters on her keyboard. It was shift work.
lol i have 2 arms i just cant be fooked with dp,DP as same thing , why has this forum not got ai to fix things like this ,its fkn 2019 ffs ;)
