HDR On = Flickering white dots !
Booker
For some reason when i have HDR enable, i have artifacts on image. 1 pixel flickering white dots.
I don´t have my VC overcloced at all.. their clocks are from factory.
And the weird thing is... this only happen when i have HDR enable..
the only game i was able to try is HL2 Ep. 1
I tried to play another game to check if it was the game but i don´t own other HDR game...
any ideas?
here is a screenshot to show how those dots looks like.
That is artifacting. Your card is being pushed too much. If its overclocked, clock it back to stock. If it isn't, it may be overheating...if you have an aftermarket cooler then it may be dying but I don't think it is so fiddle with it a bit. HDR may be killing the card.
i guess is overheating because i didn´t overclock it.
THere is any way to find out their actual clolck without installing a 3rd party software?
on the CCC panel it says..
Graphics Card Manufacturer Built by ATI
Graphics Chipset RADEON 9800 PRO
Device ID 4E48
Vendor 1002
Subsystem ID 0002
Subsystem Vendor ID 1002
Bus Type AGP
Current Bus Setting AGP 8X
BIOS Version 008.015.058.000
BIOS Part Number BK-ATI VER008.015.058.000
BIOS Date 2003/10/17
Memory Size 128 MB
Memory Type DDR SGRAM / SDRAM
Core Clock in MHz 378 MHz
Memory Clock in MHz 338 MHz
Primary Display Yes
So yeah.. they are at factory clocks...
i checked the cooler (factory cooler as well) and is spinning as normal... why is overheating :(
what i can do?
Radeon 9800 is not a old card but 3d cards like any other hardware out there, just die over time :(
When a card is in that point (artifacting with stock cooler) I would not buy 3rd party cooler for it. Good 3rd party cooler costs almost as much as your card is worth anyways, so I would start thinking about a new 3d card. I would however make sure and try running your machine with computer case open and see if its artifacting still. If it is, your card is most certainly doomed.
That actually looks more like a video memory issue, not the gpu itself.
I will loose too much power with those settings ?
on the other hand.. is not weird to have this problem when HDR is enable and don´t experience artifacts with any other game out there ?
I played Far cry, fear, medieval total war, etc and not a single issue.
I decided to re play Half life ep. 1 and this is happening... and only when i have HDR on.
If my video card is broken... it should be doing artifacts with more settings.. or i´m wrong?
well i´m really confuse... I play for an entire hour.. trying to take a screenshot of my actual game.. and i only saw 2 or 3 white dots.. and this only happen if i moved... when the Flashlight was on.. after that.. not a single white dots..
I´ll try to keep playing.. to reproduce the white dots so i can take a screenshots.
Yesterday i tried the ati test tool.. for only 10 min.. but at least it didn´t find any artifacts on those 10 min...
what is going on ???
:confused:
Well i don´t know what to think. I played again and not a single artifact.
I actually finished the game...it took me 2hs.. and no artifacts.. i really doubt my vc is faulty.
Usually "snow" (flickering white dots) is an issue of the the memory, and artifacting (big black tris/polygons flashing on the screen OR weird geometry shooting off objects) is an issue with the core speed/temps. :)
*points at post earlier*
