HDR Lighting *or* AA? Why not both?
OBSESSION
I'm no expert on these things. Didn't even really know what they were until I looked them up on Wikipedia. Both look like good features to have enabled if the game and hardware supports it.
Well, my new rig has an 8800GTX. So for the first time I'm able to play Oblivion in all its glory. However, I see that I can have HDR or AA, but not both. Is this a common limitation in all games, or just Oblivion? Which feature am I better off leaving enabled?
It's a limitation of specific NVIDIA cards. Not yours, however. Yours fully supports AA and any form of HDR.
What you need to do is select the AA level in the NVIDIA control panel, set the preference to "Application Override" (I believe), then enable HDR in the Oblivion launch/config. You're done.
Bethesda denied us the ability to select both in the launch pane because A) only some ATi cards supported fp16 HDR and AA at the time of release and B) because giving PC users the same experience as X360 users is not something that Bethesda deems is important.
lol, even without having both on at the same time, the pc version looks much much better than the 360 version. I was playing it at my friends before I had the pc version and it's almost like there isn't any AF in the game maybe 4 samples max. Distant textures are a blurry mess. Other things are cranked down also, but hey, they got aa and hdr!!! ;)
