it's a different implementation. and you can change the levels of brightness in far cry you knowheadless said:HDR is used in a couple of spots -- buggy level, where you are in the tunnels, exit of tunnels.
Isn't as overbearingly fugly as farcry's![]()
NOTD665 said:1. The Source engine does in fact support HDR.
2. There is no HDR to be found in HL2.
i believe so, although i think incompatible isn't the correct word. i just don't think todays hardware can handle using both inconjunction with each otherrobberbaron said:Is it just FarCry's implementation of HDR that is incompatible
