Bieberfever
- Aug 1, 2014
Just wanted to make people aware that HDPlex has released a new PCIe 3.0 16x riser card and the thing is beautiful. Unlike most of the other products on the market (I have a Li-Heat as well as a number of standard issue cables), this thing is massively pliable and much lighter than anything else I've seen. It also allows hard bends easily which the other risers I've come across do not. I believe it is shielded and that the primary difference between this cable and the others is that it is a silicon laminated bunch of traces versus plastic encased cables. If that isn't enough, it looks like it's made of solid gold which is pretty cool when compared with standard issue bland beige. Check it out here
http://www.hd-plex.com/HDPLEX-Silicon-PCIEx16-3.0-Flexible-Riser.html
