I'm getting a decent Pioneer receiver tomorrow or the day after, Dwolla withdrawals permitting. Not entry-level but not expensive either. It does HDMI sound, 3D passthrough, etc. My GTX 275 lacks HDMI out, so I'm going to be using optical out from the PC instead. It's going to be hooked up to a decent 5.1 speaker system. How much of a difference is there between optical and HDMI sound? Can I buy a ~$50 Nvidia GPU, throw it in underneath the existing one, and only use it for sound? Would that be worth it? The receiver does all the HDMI-exclusive lossless decoders. Regardless of that, I plan to switch out my 275 for a GTX 680 as soon as those hit market (later this year?).
Is ~$50 on a second GPU just for HDMI out instead of optical out worth it? Or would I be hard pressed to notice any difference?
Also I want a tuner card + remote for bedroom use, since my bedroom TV broke, and I've moved my monitors and computing area across from the bed. Don't really intend to record too much or try and watch multiple channels at once.. It seems like all the ones people don't hate and give terrible reviews to are ~$100. Is it really that hard to make a tuner?
