I'm about to buy the LG LDA-531 DVD player and it does 1080i and 720p upconverting.
My TV is a Viewsonic 27" LCD TV that supports 720p. It does not support HDMI, but does support component.
So as you can tell I want to use this DVD player to upcovert my video to 720p onto this TV.
The tricky part is that this LG dvd player will only upconvert to 1080i and 720p for non-copy protected DVD if I use Component video connection.
But there is a work around. This DVD player will upconvert EVERYTHING including copy protected DVDs if I use the HDMI connection.
More information and reviews of the dvd player here
I only have so many blank DVDs to make backup copies of my movies so it would be best to use HDMI.
As you know my TV does not support HDMI, and I would like to convert the HDMI to DVI so I can use it with my TV.
The question is; is there any video quality lost going from HDMI to DVI? Or any disadvantage at all? Or will I not be able to tell a difference.
Thanks.
Thanks.
