Tekara said:uhm. . . . can't remember the number of connectors needed for HDMI off hand, but if your able to conjure up a custom adapter it probably could work. Cat5 cable is fairly excellent at transmitting signals due to it's low inductance.
Basic idea is that you chop the HDMI cable in half and attach a ethernet cable or two so that you can connect it to through the wall.
