HDMI <-> DVI Adapter and Back Again
Status
Not open for further replies.
EvilAlchemist
I am building a house and had the electrician install a empty conduit so I could run my monitor cables threw the wall.
The issue I am hitting is the conduit is not large enough to run a DVI cable threw.
The only idea I came up with is using a DVI --> HDMI adapter, then using a HDMI --> DVI cable to connect to the monitor.
I tried it on a monitor and it seems to be working fine ...
Is this a good idea to do or will there be some unforeseen problems doing this down the line?
I am open to other suggestions if you have them
If its working than its working. ;)
HAHA .. true ...
I guess I fear using 2 adapters, i will loose image quality or something.
I guess since they are both digital formats, i won't but wanted to get some more imput from users who know far more then me.
Status
