HDMI audio and Performance clocks
vick1000
I recently hooked up my 560ti to my AVR by way of HDMI to get proper 5.1 in games (works perfectly on Dolby Digital gmes). I also have my 24" monitor hooked by way of DVI, and just relaized that Adaptive power clocks are now history. I would eliminate the DVI, but my reciever seems to only support 1080p and my monitor is 1920*1200.
So I am wondering if I get a cheapo nVidia card, could I run it non-SLI and hook up the monitor to it, then get my Adaptive clocks back on the 560ti with HDMI on it. Or would a HDMI splitter of some sort work?
I have read online that GPU2 will retain the performance clocks while allowing GPU1 to adapt-clock normally.
So any suggestions? GPU idling in the low 50s is crazy.
EDIT: Now Media Center is giving some error when I try to watch TV, Some video files not installed or something.
Are you only worrying about the temps? As long as the power consumption doesn't bother you, there is absolutely no harm in a video card idling at 55C. A lot of cards in the past were designed to idle at 65-80 for quietness.
Well I figured a few things out.
First, I fixed the Media Center problem by disabling menu sounds (thank you internet). I also found out that I cannot get HDMI pass through on my monitor, it defaults to 2 channel just as normal SPDIF with the coax, no suprise there.
So I'm stuck with ~50c idle temps if I want proper surround with my AVR. Just for info, the Realtek chip Dolby Digital Live does not produce positional audio in games, not over Toslink anyway. Really wish there was a way to just use the audio stream on the HDMI port on the 560ti, I'm sure it could be implemented in a driver.
Found a solution, the only solution. So for internet searchers, hope you have a SLI motherboard. I bought a cheap Geforce 210 with HDMI, hooked up the AVR to it, and both cards now adapt clocks as normal.
