SudburyOntario
- May 5, 2008
I would like to ask what the best choice on using a computer hard drive would be ?
1. Would it be best to use One hard drive and partition it so the main is the OS and the secondary is for files.
2. Use Two hard drives, the main for the OS and the Second for files.
3. Using Two hard drives in a Raid setup.
Only running the pc as for entertainment. ( not much else I can do with one - give ideas )
Thank you.
Thank you.
