HDD Storage Rack?
Hi all,
Ive been searching everywhere but not sure where to get these.
Im looking for HDD bays that are like the Pic below. I will be modding it to fit into a case but not sure where/how to search for them.
I just need the rack part with the pull out trays and dont want the server looking ones.
Any suggestions would be appreciated! Thanks!
Ide actually like some of those as well. I think you might be able to get some from Antec - they have a number of cases with racks like that. I ended up getting a friend to 3D print some brackets to mount my drives in 5.25 bays.
the prices listed on corsair's site are actually quite cheap :)
Yeah I thought it would be more expensive like the 900D cage but some of them are cheap.
I didn't see it until I was looking but if I grabbed that 900D sata hotswap PSB and put it into my server it would make cable management and routing so much easier.
Nice! Thats exactly what I was looking for. Thank you. I searched for hours too and couldnt seem to find anything.... Thats how my day seems to be going..
I am going to be putting this in the bottom of a DD Waterbox Plus.
Its torn apart right now for a rebuild/upgrade and couldnt stand the HDD configuration for it.
Thanks again.
I think the image you posted gives the game away;)
Code:
http://www.techpowerup.com/reviews/Corsair/Graphite_600T/images/innerfronthdd3.jpg
