Hello,
I am building a new pc and I am having problem with the HDD. My motherboard is an ABIT IC7-G... I bought a 200gb HDD SATA 150 but it doesn't seem to be working, even though it is recognised in the bios (appears next to IDE channel 1 master)... Not sure if it could be the reason but I read in the motherboard manual that "The Serial ATA controller only supports ultra DMA/ATA100 or higher hard drive"... I am not enough familiar with that to tell whether it is the reason or not but i am sure someone could shed a light on this...
When I boot up the pc, i have the following message : "Disk boot failure, insert the system disk and press enter" ... I inserted the disk and about 15 seconds after i have "A:\>"... I put next to it "C:\" but i have a message saying "invalid drive specification"...
Not sure what I am doing wrong here !!!
My second problem is that the CD-ROM I am using (I plugged it in the IDE1) appears in the bios under "slave"... I cannot manage to set it up under master... I tried lots of different things to make it works but it always appears under "slave" ... either IDE1 Slave or IDE2 slave
I suppose that I can use both a IDE1 slot and SATA slot at the same time???
Please help me,
Many thanks
Please help me,
Many thanks
