Well, it's Christmas time around here. I've decided I need another hard drive. My budget will be $150 tops. I'm debating whether to get a cheap SSD or put some normal SATA drives into a RAID 0 configuration. Or just get a normal 1.5TB drive.
SSD options
$124.99 32gb Patriot http://www.newegg.com/Product/Product.aspx?Item=N82E16820220341
$129.99 40gb Kingston http://www.newegg.com/Product/Product.aspx?Item=N82E16820139081
$149.99 64gb Kingston http://www.newegg.com/Product/Product.aspx?Item=N82E16820139006
$119.99 1.5TB Seagate 1.5TB 7200.11 http://www.newegg.com/Product/Product.aspx?Item=N82E16822148337
(2) $69.99 750gb Samsung Spinpoint F1 http://www.newegg.com/Product/Product.aspx?Item=N82E16822152100
Hard drives are the one category of hardware I've never been "hardcore" into so to speak. From the reviews of the Kingston SSDs (V series), they seem to be a little faster than most SATA drives? I was wondering if I should just get a cheap Kingston SSD or would 2 750gb in a RAID0 be just as fast?
My current hard drive configuration is as follows:
500gb Western Digital SATA (Windows 7)
200gb Western Digital IDE
160gb Maxtor IDE
Thanks guys
SSD options
160gb Maxtor IDE
Thanks guys
