HDD problem and question
xxxchris03xxx
i've got 2 HDD's. 1 x 130GB WD(ide) and a 250GB SATA. i just installed XP on the 130gb one and then put the sata one in my computer. I get into windows and it says the 130gb is only 6GB big and i have 100MB of space left. To my understanding RAID will just take those 2 HDD's and make them one big one. Will RAID 0 or 1 be better for me?
It sounds like you've got it partitioned strangely. Open "Computer management" (under Admin tools) and make sure you've got one partition over the whole disk.
under "control panel" or on the start menu if you enable it.
xxxchris03xxx said:
I found computer management. how do i tell if its partioned correctly?
Thanks
-Chris
Click on Disk management
look for the drive on the bottom half of the interface
  • if it's one long partition with a label like "C: 130 GB" then it's right
  • if it's one small partition with a label like "C: 6GB" and then blank space to the right it's wrong and you can add another partition to take up the rest of the space.
  • If it's one small partition and then there's another one, it's right, but you can't get any more space out of the drive.
it says
disk 0
"C: 112GB FAT32
healty (system)"
disk1
"HP_RECOVERY HP_PAVILLION
D: 8.01GB FAT32" E: 224.6GB NTFS"
(C: is the one where it only says i have 5GB of space)
i have windows installed on C: (an older HDD) then put the HDD i was using untill i had to install XP in, and its D: and E: Would RAID solve my problem? and will raid still work if one of those is PATA and the other one is SATA?
I'd run chkdsk on the C: drive, and if possible to reinstall (eg there's nothing else on there) do so with NTFS. Much more stable file system.
i figured it out. i was installing windows 98 and it was formatting my drive to FAT32. i found a copy of 2000 and installed that, then installed XP. works fine now!
