The system: Asus P4C800-E Deluxe 3.2Ghz Intel Northwood (not overclocked), 1GB of Corsair DDRAM (4 modules), BFG 9800GT OC, Adaptec 29320 SCSI controller, Maxtor Atlas 15K 18GB SCSI drive, Plextor SATA CD-RW
The system (home use only) described has been in operation for over 12 months without any boot problems. Recently, the bios reports no HDD found on boot. Pressing F8 for BBS does not display HDD on list. Have cleared CMOS, updated BIOS from 1016 to 1023 problem persists. Have swapped out Adaptec 29320 with Adaptec 19160, disconnected SATA CD-RW and same thing occurs. System boots to an IDE drive without a problem. Adaptec 29320 installed in PCI5. May require as many as 5-6 Cntl+ALT+DEL reboots before successful boot to Window XP SP2 desktop. My amateur conclusion is MB gone bad?
Any suggestions?
Thanks....
Any suggestions?
Thanks....
