I bought two Maxtor 60gb each and one took a crap about two weeks ago. Now the other one after I installed it was running fine until today. I noticed when I started to install programs in the pc that got a message telling me that the c: drive was running out of space and I had only installed 3 games ( and I'm talking about a kiddie games, in other words they don't take much space) and when I checked it was showing only a total of 2gb when the hdd like I said is 60.
I checked the bios and is recognizing the 60 but not XP. Like I said it was not doing that before. Should I try to reformat the hdd and reinstalled XP or should I get a new hdd. Both of them I bought them used from someone in the forum and I don't know if this is something that you should by used. What should I do?
Is an old system
P2 333 mhz cpu
PC100 320 mb
WinXP pro
Unknown Vid card(at least i don't know the brand right now, but i can check if necesary)
Is an old system
P2 333 mhz cpu
PC100 320 mb
WinXP pro
