HDD grinding noise depending on configuration
kingmint
Hello,
I wonder if anyone can help me with this problem:
I have just ordered a Seagate Barracuda ST3200822A HDD to replace my ageing Maxtor. I started with both drives connected and copied my 20gb of data to the Seagate. I then removed the Maxtor, put the Seagate in the HDD bay and installed XP.
The Seagate then started making very loud grinding noises during disk access. I did not remember this noise during the data transfer described above, and I ran the above procedure again to make sure. I confirmed that when booting off the Maxtor and transferring 20gb of files to the Seagate there is no grinding noise. I removed the Maxtor and installed XP on the Seagate again, and the noise returned.
I am not sure if this is a related issue, but I cannot boot the Seagate off the Master (black) ATA connector, regardless of the jumper setting.
I am not sure if my Seagate drive is faulty because when booting off the Maxtor the Seagate makes no noise.
Hope someone can help
Many thanks
Eric
as far as booting its likely a BIOS Boot order issue
but grinding = RMA time regardless
Depending on how and where a HDD is mounted inside a case, noises the HDD makes may be amplified.
I agree that grinding noises are cause for concern.
