HDD Cooling
AtomicMoose
What do you guys recommend for Hard Drive cooling these days? I am not looking for a water setup. I have 3 drives in my main box, and they are starting to get real hot.
Make me some recommendations. :D
If you have the option with your current case I'd just look at putting a fan in. One 80mm fan will do a decent job of cooling up to 3 3.5' hd's if they are in drive cage. Really, some type of fan is your best bet.
The Zalman coolers are moderately effective, but they require a fan to work. About the only solution that doesn't require air flow is water cooling which you don't want to do.
