ok, so there is un-used space on my hard-drive, that still probably has data on it (from deleted files) that could be recovered (since generally the headers are deleted, and NOT the actual data when a file is removed).
are there any applications that will write all zeroes or an algorithm over the FREE SPACE of a drive or partition that is actively in use (e.g. no full/low level format)?
thanks,
thanks,
