hdd and power leds dont work.
Tony Montana
if the case is new maybe the led's were doa... try hooking other leds up to ur mobo... if they dont work its ur motherboard... and then try hooking up the case to another mobo and if the leds dont work its the case
Might help to see if you plugged them right, that is, if the polarity is in the right order, check your mboard manual, or to be easier, just switch it around, the wire plug that connects to the mobo i mean.
No problem m8, glad to help, i Supposed it was that because i am a computer tech for 15 years now and i have seen computer assembled by other companies with the same problem, by peopel that are supposed to do better! :)
