Flogger23m
- Jun 19, 2009
Hello. I recently decided to run Speed Fan's SMART test. This time the results were different and it is worrying me:
http://i995.photobucket.com/albums/af73/Flogger23m/Untitled.jpg
Until recently, everything was the same accept for the Offline Uncorrectable Sector Count, which used to be at "Very Good". Likewise, fitness used to be at 94%, now it is at 0%. I recently scanned with HD tune and no bad sectors showed up though... that was a few days ago. It seems like accessing files creates a louder noise than usual and seems to make my PC stutter a bit more than it did in the past, which prompted me to run speed fan. The noise may very well likely be the fact that all of my fans are now turned down because it is no longer summer, but I do think I notice some stuttering.
The HDD is almost 3 years old and is OEM, would WD send me a replacement? I am going to send them an email to confirm. And if it is indeed failing and I request an advanced replacement, is there any program that can copy my Windows install, files and folders onto a replacement drive? I understand I'll have to call MS to reactivate my Win 7, but can it even be done?
Update from WD:
Looks like I have to run the Data Lifetime Diagnostic Tool. Hopefully that won't finally kill my drive.
Update from WD:
We are sorry for the delais in response to your inquiry. In this case, it seems that the application used is not fully recognizing your WD Caviar Black, it has limited access and parameters accuracy to be a reliable diagnostic information source (for this particular product). Due to that, we suggest you to diagnose (and repair if required/possible) your drive using the Data Lifetime Diagnostic tool (details bellow):
If this is a secondary drive in your computer:
