HDCP LCD Monitors?
indeed i do, the dell 2407WFP does 1920*1200 and is a 24" LCD/TFT/whatever :p
It has a few problems. The component input is bad, but i've heard if you turn off the image processing in the service menu that this problem is rectified, though it voids your warranty.
Another problem is the lack of 1:1 pixel mapping for 1080p sources. Other sources, such as 720p can 1:1 fine, but 1080p wont, it stretches to fill the screen.
Also, if you get a revision A00, A01, or A02, banding problems are severe, or so ive heard, in gradients, and some games especially (F.E.A.R.) being a good example.
The monitor is however, relatively cheap, although the price changes quite often, so you can end up getting a great deal, or kicking yourself for buying at the wrong time.
