HDCP in NEC 2690
andyo
Hi, I'm wondering if anyone's tested HDCP on this monitor. I have had it for a while and it's been working OK, but I recently got an HD-DVD drive and it doesn't work with HD-DVD movies under Windows Vista. With XP is OK, but I have the suspicion that XP doesn't require HDCP.
With Vista, in my other PC, I have the Radeon HD 2400 pro, and when running the cyberlink HD-DVD advisor, I get "Video connection type" as "Digital (without HDCP)" and it's red (not compatible). The graphics card and other entries are all green, meaning they're OK.
Under Windows XP and the X1900 GT (not HDCP enabled, as far as I know), I get all entries green, and this is using the same cable and the same monitor input, with the same input settings in the monitor and HDCP OFF in the monitor, which leads me to believe that Windows XP doesn't manage HDCP and you can just connect any non-HDCP digital monitor.
But Vista, all input combinations in the monitor (HDCP on/off, same/different cables, DVI-I and DVI-D inputs) lead me to a red dot and not being able to play HD-DVDs in PowerDVD 7.3. Anyone knows what's up with that?
And worse of all, I just found out that if you do enable HDCP in the monitor, the max resolution drops to 1280x720. What's up with THAT! I certainly hope travbomb gets the scoop on this one!
Any help is appreciated. Thanks.
