HDCP fiasco status?
zzz
Remember the HDCP fiasco, which came out Feb 2006? What has changed since then? Does every aftermarket video card still not actually support HDCP?
If a device doesn't support HDCP, does it currently matter since the ICT bit isn't enabled on any movies, and won't be until at least 2010?
I'd like to know that also. Which video card is NOT HDCP compatible? I don't want anything to do with any hardware that supports this crap. My C-Band satellite system's HD decoder works with component output, and I plan to get an R5000-HD system installed to record HD to my computer's hard drive, which is why I want a "clean" video card.
