I can only choose one to go with. Which one should I get? I've started using my old kinyo 5.1 headphones for gaming and music from the computer cd and radio. They thump and sound so good I might buy some tritton ax 720 to game with later on. But my new yulong mark II is coming next week so I want to make the right decision either dt880 32ohm or 595 sennheiser both are open ear cans. Not sure how good the amp on the dac drives but will soon find out. I am planing on using a toslink or coaxial from xfi elite pro to the dac or even from usb whatever works best. These were are my choices for all around headphones for everything on the computer including the radio but if you want you can recommend something else like grado or akg.
Thanks
