HD5870 Benchmark request
Griff805
Can someone with a HD5870 run the Microstation benchmark for me: http://appsnet.bentley.com/mstnbenchmark/MstnBenchmark.exe
Quick and easy. Just uncheck both options before you run it and when it finishes just save a local copy when it asks you and post those results for me. Only takes about 1 min to download, then about 30 seconds to run. Thanks-
Also, be sure to list your CPU and what it's running at. Thanks again-
win 7 ultimate 32bit
c2duo e8600@4.3ghz
x38 471 mhz fsb
4 gig memory 1141 mhz 5-5-5-15
5870 @ 950/1300
B-Spline Surfaces 147.5 fps
Filled Hidden Line 151.1 fps
Geometric Primitives 110.0 fps
Geometric Primitives (Anti-Aliased) 94.0 fps
Pattern Fill 116.9 fps
Raster 102.0 fps
Shaded Mesh 193.6 fps
Text 122.6 fps
Average(s) 129.7 fps
Shadows Comparison
Shadows Disabled 3851.9 fps
Shadows Enabled 864.5 fps
Delta(s) -2987.4 fps
Buffer Tests
Copy Buffer 4530.2 fps
Element Dynamics 17073.7 fps
Walkthrough Diagnostic
Occlusion Testing Disabled 40.9 fps
Occlusion Testing Enabled 53.8 fps
Delta(s) 12.9 fps
Thanks. Anyone else getting the same results? Benchmark seems to be very CPU dependent. So, I wouldn't expect much variation unless your CPU is at a much different clock.
With the specs in sig. What the hell? Mine are a lot lower than NeonGuy. Scratch that, not a lot lower, I'm getting HALF the performance NeonGuy is getting. What is up with that?
B-Spline Surfaces 74.3 fps
Filled Hidden Line 73.3 fps
Geometric Primitives 48.8 fps
Geometric Primitives (Anti-Aliased) 48.7 fps
Pattern Fill 55.0 fps
Raster 43.8 fps
Shaded Mesh 95.3 fps
Text 57.0 fps
Average(s) 62.0 fps
Shadows Comparison
Shadows Disabled 2050.3 fps
Shadows Enabled 352.0 fps
Delta(s) -1698.3 fps
Buffer Tests
Copy Buffer 2471.0 fps
Element Dynamics 4474.0 fps
Occlusion Testing Disabled 18.9 fps
Occlusion Testing Enabled 17.7 fps
Delta(s) -1.2 fps
Change your CPU speed and see what happens. 4.3Ghz vs 3.4Ghz is a big difference for this benchmark. Although, your numbers do seem lower than they should. Did you make sure to uncheck the options for "Run at native resolution" and "Test all Monitors"?
It should run at the standard 1024x768
OMG. My cpu overclock got reset. I was running at 2.4! Just changed it and now here are my numbers.
B-Spline Surfaces 106.3 fps
Filled Hidden Line 103.0 fps
Geometric Primitives 67.0 fps
Geometric Primitives (Anti-Aliased) 66.7 fps
Pattern Fill 77.7 fps
Raster 62.3 fps
Shaded Mesh 99.3 fps
Text 86.0 fps
Average(s) 83.5 fps
Shadows Comparison
Shadows Disabled 3012.3 fps
Shadows Enabled 541.3 fps
Delta(s) -2471.0 fps
Buffer Tests
Copy Buffer 3861.0 fps
Element Dynamics 7737.3 fps
Occlusion Testing Disabled 22.4 fps
Occlusion Testing Enabled 31.3 fps
Delta(s) 8.9 fps
My friend's machine - He has the same setup as mine except a 4870. How the hell does he produce bigger numbers? He's on Windows XP 32 is the only other difference.
B-Spline Surfaces 103.3 fps
Filled Hidden Line 125.0 fps
Geometric Primitives 82.3 fps
Geometric Primitives (Anti-Aliased) 82.0 fps
Pattern Fill 122.3 fps
Raster 82.0 fps
Shaded Mesh 96.3 fps
Text 95.7 fps
Average(s) 98.6 fps
Shadows Comparison
Shadows Disabled 2394.3 fps
Shadows Enabled 550.3 fps
Delta(s) -1844.0 fps
Buffer Tests
Copy Buffer 3049.0 fps
Element Dynamics 10146.0 fps
Occlusion Testing Disabled 36.7 fps
Occlusion Testing Enabled 44.7 fps
Delta(s) 8.0 fps
Heres a 5970 single
Graphics Benchmark Results
Drawing Test Name Screen #1
B-Spline Surfaces 144.5 fps
Filled Hidden Line 167.4 fps
Geometric Primitives 128.5 fps
Geometric Primitives (Anti-Aliased) 129.9 fps
Pattern Fill 130.5 fps
Raster 102.3 fps
Shaded Mesh 186.0 fps
Text 121.9 fps
Average(s) 138.9 fps
Shadows Comparison
Shadows Disabled 3242.8 fps
Shadows Enabled 860.5 fps
Delta(s) -2382.3 fps
Buffer Tests
Copy Buffer 3750.8 fps
Element Dynamics 15667.6 fps
I'm not sure- I'm trying to figure out what effects this benchmark the most as it is supposed to give me an idea of how the software I use for work will perform. I'm finding that a GTX 285 gets beat by an HD4850. So, it obviously is not all about the GPU.
With the 5970, as far as I know, the benchmark doesn't utilize both GPUs. I found this to be true with a 4870X2 vs a 4870. So, theoretically, a 5870 should be able to match a 5970.
HD 5850 at stock clocks
B-Spline Surfaces 133.7 fps
Filled Hidden Line 152.3 fps
Geometric Primitives 117.3 fps
Geometric Primitives (Anti-Aliased) 118.3 fps
Pattern Fill 121.3 fps
Raster 96.0 fps
Shaded Mesh 176.0 fps
Text 112.7 fps
Average(s) 128.5 fps
Shadows Comparison
Shadows Disabled 3038.3 fps
Shadows Enabled 766.3 fps
Delta(s) -2272.0 fps
Buffer Tests
Copy Buffer 3470.0 fps
Element Dynamics 17101.7 fps
Occlusion Testing Disabled 40.7 fps
Occlusion Testing Enabled 53.7 fps
Delta(s) 13.1 fps
(-) Video Card and Screen Report
Primary Screen (#1)
Video Device Name ATI Radeon HD 5800 Series
Resolution 1024 x 768
Color Depth 32-bit
Total Video RAM 1024 MB
Driver Version 8.673.1.0
Driver Date 11/23/2009
(+) System Information Report
Processor (Primary)
Name Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
Clock Speed 3800 MHz (3800 MHz Maximum)
Architecture x64
Number of Logical Processors 8
Memory
Total Physical 4087 MB
Operating System
Name Microsoft Windows 7 Ultimate
Build & Service Pack Build 7600 (No Service Pack)
Is 64-bit Yes
HD 5850 at 1000core and 1250 memory, it is stable have played dirt2 for a few hours at those speeds. it doesnt make much difference other than couple of tests, at that resolution I guess it is more cpu than gpu.
B-Spline Surfaces 130.0 fps
Filled Hidden Line 152.7 fps
Geometric Primitives 117.0 fps
Geometric Primitives (Anti-Aliased) 116.7 fps
Pattern Fill 119.3 fps
Raster 94.0 fps
Shaded Mesh 188.0 fps
Text 111.7 fps
Average(s) 128.7 fps
Shadows Comparison
Shadows Disabled 3757.3 fps
Shadows Enabled 763.7 fps
Delta(s) -2993.7 fps
Buffer Tests
Copy Buffer 4538.7 fps
Element Dynamics 14449.0 fps
Occlusion Testing Disabled 40.3 fps
Occlusion Testing Enabled 54.0 fps
Delta(s) 13.7 fps
Primary Screen (#1)
Color Depth 32-bit
Processor (Primary)
Architecture x64
looks like the test is very cpu limited.. just screwed around with it on my GTX 260 since i've never seen the program before.. but loading up 1 core on my phenom II 940 cut my frame rate in half.. also i wonder if the aero on w7 desktop has an effect on performance as well which could be why your friends system did better then your system Justinsane since he was on XP and doesnt use aero.. but i guess i could test this by running it full screen with my left monitor enabled and then disable it..
darn nvm doesnt do 1920x1200..
Stock 5870 clocks.
B-Spline Surfaces 124.9 fps
Filled Hidden Line 121.6 fps
Geometric Primitives 84.7 fps
Geometric Primitives (Anti-Aliased) 83.7 fps
Pattern Fill 85.7 fps
Raster 63.8 fps
Text 98.3 fps
Average(s) 95.2 fps
Shadows Comparison
Shadows Disabled 1871.1 fps
Shadows Enabled 639.0 fps
Delta(s) -1232.1 fps
Buffer Tests
Copy Buffer 2221.2 fps
Element Dynamics 3855.9 fps
Occlusion Testing Disabled 20.9 fps
Occlusion Testing Enabled 31.7 fps
Delta(s) 10.8 fps
OC'd 5870?? (950/1350)
B-Spline Surfaces 121.9 fps
Filled Hidden Line 115.9 fps
Geometric Primitives 82.0 fps
Geometric Primitives (Anti-Aliased) 84.4 fps
Pattern Fill 82.7 fps
Raster 65.8 fps
Shaded Mesh 100.3 fps
Text 97.3 fps
Average(s) 93.8 fps
Shadows Comparison
Shadows Disabled 1994.7 fps
Shadows Enabled 647.6 fps
Delta(s) -1347.1 fps
Buffer Tests
Copy Buffer 2368.3 fps
Element Dynamics 4149.2 fps
Occlusion Testing Disabled 22.1 fps
Occlusion Testing Enabled 31.2 fps
Delta(s) 9.1 fps
I don't get it.
I'll run it when I get home on my new 5970 @ 5870 clocks, I can't do it over remote desktop from work :p
*edit*
Specs in sig, here's the results
B-Spline Surfaces 120.9 fps
Filled Hidden Line 117.2 fps
Geometric Primitives 82.7 fps
Geometric Primitives (Anti-Aliased) 83.4 fps
Pattern Fill 90.0 fps
Raster 68.1 fps
Shaded Mesh 174.7 fps
Text 97.3 fps
Average(s) 104.3 fps
Shadows Comparison
Shadows Disabled 3151.8 fps
Shadows Enabled 703.4 fps
Delta(s) -2448.4 fps
Buffer Tests
Copy Buffer 3615.6 fps
Element Dynamics 11034.9 fps
Occlusion Testing Disabled 31.4 fps
Occlusion Testing Enabled 37.7 fps
Delta(s) 6.3 fps
Specs in sig:
B-Spline Surfaces 124.5 fps
Filled Hidden Line 142.1 fps
Geometric Primitives 108.3 fps
Geometric Primitives (Anti-Aliased) 111.9 fps
Pattern Fill 113.9 fps
Raster 89.0 fps
Shaded Mesh 175.0 fps
Text 105.6 fps
Average(s) 121.3 fps
Shadows Comparison
Shadows Disabled 3335.8 fps
Shadows Enabled 728.2 fps
Delta(s) -2607.5 fps
Buffer Tests
Copy Buffer 3865.8 fps
Element Dynamics 10739.6 fps
Occlusion Testing Disabled 39.5 fps
Occlusion Testing Enabled 52.3 fps
Delta(s) 12.7 fps
B-Spline Surfaces 99.63 fps
Filled Hidden Line 119.23 fps
Geometric Primitives 78.38 fps
Geometric Primitives (Anti-Aliased) 77.74 fps
Pattern Fill 95.65 fps
Raster 68.75 fps
Shaded Mesh 108.27 fps
Text 83.39 fps
Average(s) 91.38 fps
Shadows Comparison
Shadows Disabled 2,918.63 fps
Shadows Enabled 522.42 fps
Delta(s) -2,396.21 fps
Buffer Tests
Copy Buffer 3,502 fps
Element Dynamics 11,323 fps
Occlusion Testing Disabled 25.24 fps
Occlusion Testing Enabled 32.70 fps
Delta(s) 7.46 fps
Shadows Comparison
Shadows Disabled 1799.4 fps
Shadows Enabled 492.5 fps
Delta(s) -1306.9 fps
Buffer Tests
Copy Buffer 2344.7 fps
Element Dynamics 3315.5 fps
Occlusion Testing Disabled 26.4 fps
Occlusion Testing Enabled 34.5 fps
Delta(s) 8.1 fps
Test doesn't like my Phenom II
Def seems CPU bound. Here's my 5870 with a 1366 i7 at 4.2 GHz
B-Spline Surfaces 148.1 fps
Filled Hidden Line 172.4 fps
Geometric Primitives 130.5 fps
Geometric Primitives (Anti-Aliased) 131.5 fps
Pattern Fill 136.2 fps
Raster 106.6 fps
Shaded Mesh 179.3 fps
Text 128.9 fps
Average(s) 141.7 fps
Shadows Comparison
Shadows Disabled 3548.3 fps
Shadows Enabled 902.7 fps
Delta(s) -2645.6 fps
Buffer Tests
Copy Buffer 4146.8 fps
Element Dynamics 19529.1 fps
Occlusion Testing Disabled 44.2 fps
Occlusion Testing Enabled 55.8 fps
Delta(s) 11.7 fps
The below results is for a HP z800 workstation with single E5520 Xeon CPU, 12GB memory, Sapphire HD5970. They seem faily low? This is running Windows XP 64-bit, Windows 7 64-bit returned slightly lower results again...
What I didn't expect and I am rather dissapointed about is for the Gefore GTX 295 to be signaificantly faster on the same system in several areas which are very important (red). Can anyone shed some light on a possible reason for this? Are the new drivers to blame (version 8.663):confused:
Drawing Test Name Screen #1 (ATI 5970)
B-Spline Surfaces 48.3 fps
Filled Hidden Line 120.7 fps
Geometric Primitives 68.0 fps
Geometric Primitives (Anti-Aliased) 65.3 fps
Pattern Fill 90.7 fps
Raster 84.7 fps
Shaded Mesh 136.7 fps
Text 67.0 fps
Average(s) 85.2 fps
Shadows Comparison
Shadows Disabled 1356.7 fps
Shadows Enabled 449.7 fps
Delta(s) -907.0 fps
Buffer Tests
Copy Buffer 1452.3 fps
Element Dynamics 10486.7 fps
Occlusion Testing Disabled 36.3 fps
Occlusion Testing Enabled 52.7 fps
Delta(s) 16.4 fps
Drawing Test Name Screen #1 (GTX 295)
B-Spline Surfaces 49.4 fps
Filled Hidden Line 88.7 fps
Geometric Primitives 72.0 fps
Geometric Primitives (Anti-Aliased) 65.0 fps
Pattern Fill 76.7 fps
Raster 37.0 fps
Shaded Mesh 64.0 fps
Text 67.3 fps
Average(s) 65.0 fps
Shadows Comparison
Shadows Disabled 3307.7 fps
Shadows Enabled 584.0 fps
Delta(s) -2723.7 fps
Buffer Tests
Copy Buffer 5041.0 fps
Element Dynamics 21456.3 fps
Delta(s) 16.4 fps
seems nearly worthless for a GPU test, it only increased my GPU temps by 2-3C so it definatly isn't using much gpu power.
Here's my results with a 5850, i7 920 @ 3.60GHz and 6gb ram, Win7 Ult 64bit
B-Spline Surfaces 125.9 fps
Filled Hidden Line 144.1 fps
Geometric Primitives 106.6 fps
Geometric Primitives (Anti-Aliased) 108.9 fps
Pattern Fill 107.6 fps
Raster 88.4 fps
Shaded Mesh 179.4 fps
Text 105.9 fps
Average(s) 120.9 fps
Shadows Comparison
Shadows Disabled 3032.9 fps
Shadows Enabled 731.9 fps
Delta(s) -2301.0 fps
Buffer Tests
Copy Buffer 3467.0 fps
Element Dynamics 14714.4 fps
Occlusion Testing Disabled 39.9 fps
Occlusion Testing Enabled 52.2 fps
Delta(s) 12.3 fps
yeah its 100% cpu bound.. i think it only takes advantage of the shaders on the gpu not the gpu.. not to mention the test is really only worth running on XP since aero effects the performance with it in windowed mode on vista/7..
